Ga door naar hoofdinhoud
Casio MH-10M Battery Replacement
Wat je nodig hebt
  1. Casio MH-10M Battery Replacement, BATTERY: stap 1, afbeelding 1 van 1
    • This is the calculator in question.
    • Features a black and white dot matrix screen.
  2. Casio MH-10M Battery Replacement: stap 2, afbeelding 1 van 2 Casio MH-10M Battery Replacement: stap 2, afbeelding 2 van 2
    • Turn the calculator over.
    • Locate the six screws on the rear of the device.
    • These are Philips #00 screws.
    • Keep the screws you remove in a safe place so they don't get lost.
  3. Casio MH-10M Battery Replacement: stap 3, afbeelding 1 van 2 Casio MH-10M Battery Replacement: stap 3, afbeelding 2 van 2
    • Once the screws are removed, carefully lift the back panel off, lifting the top end first.
    • Place the panel to one side.
    • You can now see the battery.
  4. Casio MH-10M Battery Replacement: stap 4, afbeelding 1 van 1
    • Remove the battery
    • Lift it up from the right hand side to avoid damaging the spring.
    • You may find this easier to do by prying it out with the screwdriver.
  5. Casio MH-10M Battery Replacement: stap 5, afbeelding 1 van 2 Casio MH-10M Battery Replacement: stap 5, afbeelding 2 van 2
    • Now you can insert the new battery
    • Ensure you place it in spring-first.
    • Congratulations! You have replaced the battery.
    • When reassembling, take care not to trap the red or black wires in the screws as this would sever them, making the calculator unusable.
    • Once reassembled, the calculator will be turned on. Turn it off to save battery by pressing Shift --> AC.
Conclusie
To reassemble your device, follow these instructions in reverse order, noting the two reassembly instructions in the last step.
26 andere personen hebben deze handleiding voltooid.
Sam
959 Reputatie
1 Handleiding geschreven
3 opmerkingen
For some reason the two top screws made the calculator unstable, but removing them made it stable. Only occurred after removing the battery
Mida Galbraith - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 4
Altijd: 49,210
