Inleiding
Do you have a Casio Edifice watch with a broken or ill-fitting band? Use this guide to fix or resize the watchband and return the watch to its former glory.
Wat je nodig hebt
Locate the hole for the pin you would like to remove.
Insert the Sim Card Eject tool (a safety pin may work as well) inthe hole. Make sure to insert in the hole on the back side of the arrow.
To disassemble the clasp, follow the last 3 steps in reverse order.
8 andere personen hebben deze handleiding voltooid.
3 opmerkingen
These are good tips. Repairing a watch can be tricky especially if moisture creeps in. If you're stuck for help, check out http://TimesTicking.com I have used them many times. Very helpful!
Hi, where can I buy link pins? I have the ones with the spring, but the others - I have not been able to find online.
Here is good chanal for watch repairing https://www.youtube.com/watch?v=n1FQgn95...
