Ga door naar hoofdinhoud
Casio MTD-120 Battery Replacement
Wat je nodig hebt
  1. Casio MTD-120 Battery Replacement, Battery: stap 1, afbeelding 1 van 1
    • Place the watch upside down.
  2. Casio MTD-120 Battery Replacement: stap 2, afbeelding 1 van 2 Casio MTD-120 Battery Replacement: stap 2, afbeelding 2 van 2
    • Remove the back cover of the watch with tweezers.
    • This should reveal a plastic cover once the back is removed.
  3. Casio MTD-120 Battery Replacement: stap 3, afbeelding 1 van 2 Casio MTD-120 Battery Replacement: stap 3, afbeelding 2 van 2
    • Remove the plastic cover with the tweezers.
    • You should now see the battery compartment.
  4. Casio MTD-120 Battery Replacement: stap 4, afbeelding 1 van 1
    • Remove the battery with the tweezers.
    • Use your fingers to remove the battery if you find it difficult using the tweezers.
  5. Casio MTD-120 Battery Replacement: stap 5, afbeelding 1 van 1
    • Insert the new battery by pushing down gently.
    • The battery needed for this watch is an SR920SW.
    • Recycle the old battery.
    • Where To Recycle Batteries
  6. Casio MTD-120 Battery Replacement: stap 6, afbeelding 1 van 2 Casio MTD-120 Battery Replacement: stap 6, afbeelding 2 van 2
    • Place the plastic cover back over battery compartment.
    • Align the marked area of the plastic cover with the crown of the watch.
    • The crown is the knob that is used to set the watch.
  7. Casio MTD-120 Battery Replacement: stap 7, afbeelding 1 van 1
    • Put the cover back and tighten it shut by pressing on it.
Conclusie
Follow the link provided in step 5 to find more information on recycling your old batteries.
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 16
Afgelopen 30 dagen: 34
Altijd: 4,526
