Ga door naar hoofdinhoud
Casio LK-170 Key Replacement
Wat je nodig hebt
  1. Casio LK-170 Key Replacement, Key: stap 1, afbeelding 1 van 3 Casio LK-170 Key Replacement, Key: stap 1, afbeelding 2 van 3 Casio LK-170 Key Replacement, Key: stap 1, afbeelding 3 van 3
    • You will be removing 17 11mm screws with a JIS-1 screwdriver to detach the back of the keyboard from the front.
    • You will begin by removing 4 screws on each side of the piano, circled in red.
    • You will then remove the four screws that are a little hidden, circled in orange.
    • Next, remove the two screws in the middle of piano, as well as the three screws on the top of the piano, circled in yellow.
  2. Casio LK-170 Key Replacement: stap 2, afbeelding 1 van 2 Casio LK-170 Key Replacement: stap 2, afbeelding 2 van 2
    • After flipping the keyboard over to the front, carefully remove the the front panel from the back panel of the keyboard using your hands.
    • You should now see the screws holding the keys in place.
    • There are five 18mm screws per section of keys.
    • With a JIS-1 bit, unscrew the five screws in the section with the key you want to replace.
  3. Casio LK-170 Key Replacement: stap 3, afbeelding 1 van 2 Casio LK-170 Key Replacement: stap 3, afbeelding 2 van 2
    • You will be able to pick up the white keys with your hands and remove them.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Samantha Baker
425 Reputatie
4 handleidingen geschreven
Cal Poly, Team 13-2, Banghart Winter 2017 Lid van Cal Poly, Team 13-2, Banghart Winter 2017
CPSU-BANGHART-W17S13G2
3 Leden
5 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 27
Altijd: 2,399
