Inleiding
In this guide, we will be completely disassembling the phone down to the core to remove the camera and replacing it with a new one.
  1. Slide the slider on the back of the phone to the free position.
    • Slide the slider on the back of the phone to the free position.
  2. Using a plastic opening tool, gently lift open the back panel from bottom of the panel.
    • Using a plastic opening tool, gently lift open the back panel from bottom of the panel.
    • Pull the white battery tab upwards and remove the battery.
    • Remove the four 6mm Y0 screws from the corners of the device.
    • Remove the four 5mm Y0 screws from the back of the device.
    • Using a spudger, pry away the motherboard from its compartment, by inserting the spudger in the compartment and lifting upwards until fully out.
    • Lastly, using your hands, separate the motherboard from its compartment.
    • Using a spudger, gently lift up the orange connector.
    • Flip over the motherboard
    • Using a spudger, lift up the small black connector and remove the camera.
Conclusie
Zack Almeida
362 Reputatie
4 handleidingen geschreven
UMass Dartmouth, Team S3-G7, Peak Fall 2018 Lid van UMass Dartmouth, Team S3-G7, Peak Fall 2018
UMASSD-PEAK-F18S3G7
3 Leden
6 handleidingen geschreven
Weergavestatistieken:
Afgelopen 24 Uren: 0
Afgelopen 7 Dagen: 0
Afgelopen 30 Dagen: 15
Altijd: 59
