Ga door naar hoofdinhoud
Casio G’zOne Commando 4G LTE Motherboard Replacement
Gearchiveerde handleiding
Deze handleiding wordt enkel nog bijgehouden voor historische doeleinden. Gebruik de laatste versie van deze gids om uw reparatie uit te voeren.
Wat je nodig hebt
  1. Casio G’zOne Commando 4G LTE Motherboard Replacement, Open back cover.: stap 1, afbeelding 1 van 1
    • This device is waterproof and well sealed, so it is difficult to open this handset.
    • Start by opening the cover of the handset.
    • Do not use your nails to open the cover. Use the iFixit Opening Tool (refer to the image).
  2. Casio G’zOne Commando 4G LTE Motherboard Replacement, Free and remove the battery: stap 2, afbeelding 1 van 2 Casio G’zOne Commando 4G LTE Motherboard Replacement, Free and remove the battery: stap 2, afbeelding 2 van 2
    • Move the orange tab to the right side to take out the battery.
    • Remove the battery.
  3. Casio G’zOne Commando 4G LTE Motherboard Replacement, Remove front and back screws: stap 3, afbeelding 1 van 2 Casio G’zOne Commando 4G LTE Motherboard Replacement, Remove front and back screws: stap 3, afbeelding 2 van 2
    • Using the Phillips #00 screwdriver remove the front and back 5.0 mm screws as shown in the picture.
    • There are four screws in the back and two screws in the front.
  4. Casio G’zOne Commando 4G LTE Motherboard Replacement, Remove side-Back cover: stap 4, afbeelding 1 van 3 Casio G’zOne Commando 4G LTE Motherboard Replacement, Remove side-Back cover: stap 4, afbeelding 2 van 3 Casio G’zOne Commando 4G LTE Motherboard Replacement, Remove side-Back cover: stap 4, afbeelding 3 van 3
    • Gently remove the side cover from the phone by lifting up on the corners as shown in the picture.
    • Press down on the screen to help remove the plastic side cover from the phone.
    • Make sure to push gently because the frame is fragile.
  5. Casio G’zOne Commando 4G LTE Motherboard Replacement, Remove Side-Front cover: stap 5, afbeelding 1 van 1
    • Pull the side front cover off the face of the phone.
  6. Casio G’zOne Commando 4G LTE Motherboard Replacement: stap 6, afbeelding 1 van 3 Casio G’zOne Commando 4G LTE Motherboard Replacement: stap 6, afbeelding 2 van 3 Casio G’zOne Commando 4G LTE Motherboard Replacement: stap 6, afbeelding 3 van 3
    • Remove the eight 2.5mm Phillips #00 screws in the holes of the casing.
  7. Casio G’zOne Commando 4G LTE Motherboard Replacement: stap 7, afbeelding 1 van 1
    • Gently pull off the motherboard cover.
  8. Casio G’zOne Commando 4G LTE Motherboard Replacement: stap 8, afbeelding 1 van 1
    • Using the Phillips #00, remove all 2.5 mm screws attached to the motherboard.
    • Do not touch the integrated circuits in the motherboard.
  9. Casio G’zOne Commando 4G LTE Motherboard Replacement, Motherboard: stap 9, afbeelding 1 van 2 Casio G’zOne Commando 4G LTE Motherboard Replacement, Motherboard: stap 9, afbeelding 2 van 2
    • Gently remove the motherboard with the spudger.
Conclusie
4 andere personen hebben deze handleiding voltooid.
Brett Boehm
281 Reputatie
2 handleidingen geschreven
USF Tampa, Team 1-5, Brown Fall 2014 Lid van USF Tampa, Team 1-5, Brown Fall 2014
USFT-BROWN-F14S1G5
3 Leden
3 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 1
Altijd: 822
