Inleiding
After removing the battery and motherboard from your device you will be able to simply remove the camera from the mother board after following the steps provided.
Wat je nodig hebt
First, you are going to want to take out the two front screws from the device.
The screws are 4mm in length and require a Y0 bit to remove
In order to remove the camera, carefully disconnect the wires with the metal spudger.
Één andere persoon heeft deze handleiding voltooid.
