Ga door naar hoofdinhoud
Casio G’zOne Commando 4G LTE Battery Replacement
Wat je nodig hebt
  1. Casio G’zOne Commando 4G LTE Battery Replacement, Battery: stap 1, afbeelding 1 van 1
    • In order to get at the battery, you will have to pull the locking tab to the “Free” position. Once you do that you will have to pry the battery cover off (using a plastic opening tool or similar prying tool). Because the phone is designed to be waterproof, it is advised that you do NOT use your fingernails.
  2. Casio G’zOne Commando 4G LTE Battery Replacement: stap 2, afbeelding 1 van 2 Casio G’zOne Commando 4G LTE Battery Replacement: stap 2, afbeelding 2 van 2
    • Once the battery cover is off, there is another lock holding the battery in place. However, with this lock all you have to do is slide the lock to “Free”, and pull the battery out by lifting it from the bottom side (the side with the orange lock).
Conclusie
To install a new battery in your device, follow these instructions in reverse order.
Één andere persoon heeft deze handleiding voltooid.
Daniel Keenan
374 Reputatie
2 handleidingen geschreven
UMass Dartmouth, Team 1-9, Miles Fall 2015 Lid van UMass Dartmouth, Team 1-9, Miles Fall 2015
UMASSD-MILES-F15S1G9
3 Leden
10 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 16
Altijd: 749
