Inleiding
In order to remove the battery cover, it is in the best interest of you and your fingernails to use a spudger or something to pry of the battery cover. Don't forget, you have to unlock the battery cover before you start prying it!
Wat je nodig hebt
In order to get at the battery, you will have to pull the locking tab to the “Free” position. Once you do that you will have to pry the battery cover off (using a plastic opening tool or similar prying tool). Because the phone is designed to be waterproof, it is advised that you do NOT use your fingernails.
To install a new battery in your device, follow these instructions in reverse order.
Één andere persoon heeft deze handleiding voltooid.
