Ga door naar hoofdinhoud
Casio G'zOne Commando Verizon MIL-SPEC Camera Replacement
Wat je nodig hebt
  1. Casio G'zOne Commando Verizon MIL-SPEC Camera Replacement, Battery: stap 1, afbeelding 1 van 1
    • Slide the slider on the back of the phone to the free position.
  2. Casio G'zOne Commando Verizon MIL-SPEC Camera Replacement: stap 2, afbeelding 1 van 1
    • Using a plastic opening tool, gently lift open the back panel from bottom of the panel.
  3. Casio G'zOne Commando Verizon MIL-SPEC Camera Replacement: stap 3, afbeelding 1 van 2 Casio G'zOne Commando Verizon MIL-SPEC Camera Replacement: stap 3, afbeelding 2 van 2
    • Pull the white battery tab upwards and remove the battery.
  4. Casio G'zOne Commando Verizon MIL-SPEC Camera Replacement, Motherboard: stap 4, afbeelding 1 van 1
    • Remove the four 6mm Y0 screws from the corners of the device.
  5. Casio G'zOne Commando Verizon MIL-SPEC Camera Replacement: stap 5, afbeelding 1 van 1
    • Remove the four 5mm Y0 screws from the back of the device.
  6. Casio G'zOne Commando Verizon MIL-SPEC Camera Replacement: stap 6, afbeelding 1 van 1
    • Using a spudger, pry away the motherboard from its compartment, by inserting the spudger in the compartment and lifting upwards until fully out.
  7. Casio G'zOne Commando Verizon MIL-SPEC Camera Replacement: stap 7, afbeelding 1 van 1
    • Lastly, using your hands, separate the motherboard from its compartment.
  8. Casio G'zOne Commando Verizon MIL-SPEC Camera Replacement, Camera: stap 8, afbeelding 1 van 3 Casio G'zOne Commando Verizon MIL-SPEC Camera Replacement, Camera: stap 8, afbeelding 2 van 3 Casio G'zOne Commando Verizon MIL-SPEC Camera Replacement, Camera: stap 8, afbeelding 3 van 3
    • Using a spudger, gently lift up the orange connector.
  9. Casio G'zOne Commando Verizon MIL-SPEC Camera Replacement: stap 9, afbeelding 1 van 2 Casio G'zOne Commando Verizon MIL-SPEC Camera Replacement: stap 9, afbeelding 2 van 2
    • Flip over the motherboard
    • Using a spudger, lift up the small black connector and remove the camera.
Conclusie
Zack Almeida
392 Reputatie
4 handleidingen geschreven
UMass Dartmouth, Team S3-G7, Peak Fall 2018 Lid van UMass Dartmouth, Team S3-G7, Peak Fall 2018
UMASSD-PEAK-F18S3G7
3 Leden
8 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 9
Afgelopen 30 dagen: 60
Altijd: 362
