Ga door naar hoofdinhoud
Repareer je spullen
Recht op reparatie
Winkel
Inleiding
In the event that your back plate is cracked or broken you will need to remove the back plate. This guide will show you how.
Onderdelen
Geen onderdelen opgegeven.
  1. Remove the 6  screws, which are 5mm long, using a PH1 screwdriver.
    • Remove the 6 screws, which are 5mm long, using a PH1 screwdriver.
  2. SLA DE UPGRADE OVER
    Bespaar door het te repareren met een alles-in-één kit.
    Koop iPhone-reparatiekits
    SLA DE UPGRADE OVER
  3. Use plastic spudger to separate backplate from the front-plate.  Place the flat end of the spudger in the seam between the front and back, near one end of the calculator.  Then slide the spudger towards the calculator's center.  The two sides will  pop free from each other as you go through it with the spudger. Use plastic spudger to separate backplate from the front-plate.  Place the flat end of the spudger in the seam between the front and back, near one end of the calculator.  Then slide the spudger towards the calculator's center.  The two sides will  pop free from each other as you go through it with the spudger. Use plastic spudger to separate backplate from the front-plate.  Place the flat end of the spudger in the seam between the front and back, near one end of the calculator.  Then slide the spudger towards the calculator's center.  The two sides will  pop free from each other as you go through it with the spudger.
    • Use plastic spudger to separate backplate from the front-plate. Place the flat end of the spudger in the seam between the front and back, near one end of the calculator. Then slide the spudger towards the calculator's center. The two sides will pop free from each other as you go through it with the spudger.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Lindsey Griffin
421 Reputatie
3 handleidingen geschreven
USF Tampa, Team 2-2, Nance Fall 2016 Lid van USF Tampa, Team 2-2, Nance Fall 2016
USFT-NANCE-F16S2G2
4 Leden
5 handleidingen geschreven
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 51
