Inleiding
In the event that your back plate is cracked or broken you will need to remove the back plate. This guide will show you how.
Wat je nodig hebt
Use plastic spudger to separate backplate from the front-plate. Place the flat end of the spudger in the seam between the front and back, near one end of the calculator. Then slide the spudger towards the calculator's center. The two sides will pop free from each other as you go through it with the spudger.
Één andere persoon heeft deze handleiding voltooid.
