Inleiding
This guide will describe how to replace a LCD screen for Casio Exilim EX-Z80. Before doing that, users need to take out the back and front cover then, follow the steps.
Wat je nodig hebt
Remove the four 3 mm black screws from the bottom of the camera using a Phillips #000 screwdriver.
Open the battery compartment with your thumb or index finger.
Remove the single 2 mm silver screw that is now exposed using a Phillips #000 screwdriver.
Gently flip the wide button cable up from the display cable.
Lift the brown retention flap on the display cable ZIF connector with tweezers or an ESD-safe tool.
Carefully pull the display cable from its connector.
