Ga door naar hoofdinhoud
Inleiding
If your camera displays a message that your memory is "locked," this guide will show you how to correct that. You will first be shown where the memory card is located and how to remove it. If you already know how to do so, you may skip down to step 3 for unlocking your memory card.
  1. Orient the camera with the lens facing to the right and the bottom of the camera toward you. Grasping the camera tightly, press downward firmly on the piece with the label and slide it towards the LCD screen (to the left). The flap will then swing upward.
    • Orient the camera with the lens facing to the right and the bottom of the camera toward you.
    • Grasping the camera tightly, press downward firmly on the piece with the label and slide it towards the LCD screen (to the left).
    • The flap will then swing upward.
  2. Push down on the memory card (located behind the battery) and then release pressure completely. The memory card will automatically rise part way out of its compartment.
    • Push down on the memory card (located behind the battery) and then release pressure completely.
    • The memory card will automatically rise part way out of its compartment.
    • Grasp the memory card on each side and simply slide it out of its compartment to remove it.
  3. If your memory card is locked, there is a metal slider on the left side that can be moved up to unlock the memory card. If your memory card is locked, there is a metal slider on the left side that can be moved up to unlock the memory card. If your memory card is locked, there is a metal slider on the left side that can be moved up to unlock the memory card.
    • If your memory card is locked, there is a metal slider on the left side that can be moved up to unlock the memory card.
Conclusie
Paul Fallon
135 Reputatie
6 handleidingen geschreven
Cal Poly, Team 17-28, Amido Spring 2012 Lid van Cal Poly, Team 17-28, Amido Spring 2012
CPSU-AMIDO-S12S17G28
4 Leden
14 handleidingen geschreven
2 Opmerkingen
My Casio camera works great until I insert the memory card. When it doesn't have the memory card, it turns on, the lenses come out and everything but as soon as I insert the memory card, the lenses will come out have way, and then the camera shuts off like that. The only way to get the lenses to get inside and the camera to turn on, is to remove the memory card. HELP ME PLEASE!
Miriam - Antwoord
I have a similar issue. My camera won’t recognize the SD card! It’ll turn on & take pic’s in the Memory area, but them it’s FULL after a few. Isn’t there something that can be done?
I see NO ONE HAS ANSWERED THE LAST PERSONS QUESTION….????????????
Lynn Lehr - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 7
Altijd: 2,217
