Ga door naar hoofdinhoud
Casio Exilim EX Z55 Lens Replacement
Wat je nodig hebt
  1. Casio Exilim EX Z55 Lens Replacement, Front Case: stap 1, afbeelding 1 van 3 Casio Exilim EX Z55 Lens Replacement, Front Case: stap 1, afbeelding 2 van 3 Casio Exilim EX Z55 Lens Replacement, Front Case: stap 1, afbeelding 3 van 3
    • Remove eight 1.8 mm screws from the left and right sides of the camera using a Phillips #00 screwdriver
  2. Casio Exilim EX Z55 Lens Replacement: stap 2, afbeelding 1 van 1
    • Remove the four 3.7 mm screws from the bottom of the camera using a Phillips #00 screwdriver.
  3. Casio Exilim EX Z55 Lens Replacement: stap 3, afbeelding 1 van 1
    • Separate the front case from the body of the camera.
  4. Casio Exilim EX Z55 Lens Replacement, Back Case: stap 4, afbeelding 1 van 1
    • Separate the back case from the body of the camera.
  5. Casio Exilim EX Z55 Lens Replacement, LCD Screen: stap 5, afbeelding 1 van 3 Casio Exilim EX Z55 Lens Replacement, LCD Screen: stap 5, afbeelding 2 van 3 Casio Exilim EX Z55 Lens Replacement, LCD Screen: stap 5, afbeelding 3 van 3
    • Remove the metal grating located to the right of the LCD screen by inserting the plastic opening tool under the grating and pulling up.
  6. Casio Exilim EX Z55 Lens Replacement: stap 6, afbeelding 1 van 1
    • Before removing the side metal bracket, first remove the attached strap knob by twisting it off.
    • Then, remove the side metal bracket by inserting the plastic opening tool under the bracket and pulling up.
  7. Casio Exilim EX Z55 Lens Replacement: stap 7, afbeelding 1 van 1
    • Using the plastic opening tool, pry up the LCD screen starting at one of the corners. Insert the tool under one of the corners and lift up.
  8. Casio Exilim EX Z55 Lens Replacement: stap 8, afbeelding 1 van 2 Casio Exilim EX Z55 Lens Replacement: stap 8, afbeelding 2 van 2
    • Continue to lift the LCD screen all the way up.
    • Be careful not to rip any wires connecting the LCD screen to the top of the camera.
  9. Casio Exilim EX Z55 Lens Replacement, Lens: stap 9, afbeelding 1 van 2 Casio Exilim EX Z55 Lens Replacement, Lens: stap 9, afbeelding 2 van 2
    • Remove the orange ribbon cable by grabbing the white tab and pulling back.
  10. Casio Exilim EX Z55 Lens Replacement: stap 10, afbeelding 1 van 2 Casio Exilim EX Z55 Lens Replacement: stap 10, afbeelding 2 van 2
    • Remove the two 1.66mm screws on both the bottom and top metal plates, using a #00 Phillips screwdriver.
  11. Casio Exilim EX Z55 Lens Replacement: stap 11, afbeelding 1 van 1
    • Using the plastic opening tool, pry the battery case clamps (located on front of the camera) so that the bottom portion of the camera will come loose.
  12. Casio Exilim EX Z55 Lens Replacement: stap 12, afbeelding 1 van 1
    • Once the bottom portion of the camera is removed, stand the camera upright, bottom portion facing up, then detach the inner orange strip from the motherboard to the lens by inserting the plastic opening tool under the tab and lifting up.
  13. Casio Exilim EX Z55 Lens Replacement: stap 13, afbeelding 1 van 1
    • Fully remove the lens from the motherboard.
    • It will still be attached by wires and a different orange ribbon cable.
    • You can now proceed to repair the existing lens or replace it with a new lens.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Greg Bucher
14 Reputatie
1 Handleiding geschreven
Cal Poly, Team 9-45, Regan Spring 2012 Lid van Cal Poly, Team 9-45, Regan Spring 2012
CPSU-REGAN-S12S9G45
7 Leden
14 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 24
Altijd: 1,928
