Ga door naar hoofdinhoud
Casio CTK-501 Keys Replacement
Wat je nodig hebt
  1. Casio CTK-501 Keys Replacement, Bottom Panel: stap 1, afbeelding 1 van 2 Casio CTK-501 Keys Replacement, Bottom Panel: stap 1, afbeelding 2 van 2
    • Flip the keyboard over so that the bottom is facing up.
    • Remove the twenty-seven 12 mm screws from the dark-grey panel using a Phillips #2 screwdriver.
  2. Casio CTK-501 Keys Replacement: stap 2, afbeelding 1 van 1
    • Remove the bottom panel by lifting and pulling it towards yourself.
  3. Casio CTK-501 Keys Replacement: stap 3, afbeelding 1 van 2 Casio CTK-501 Keys Replacement: stap 3, afbeelding 2 van 2
    • Flip open the top half of the keyboard.
    • Set the keyboard onto the bottom half with the internal parts facing up.
    • Be careful not to let the bottom drop.
  4. Casio CTK-501 Keys Replacement, Keys: stap 4, afbeelding 1 van 1
    • Completely unscrew and remove the screws holding the broken string of keys in place.
  5. Casio CTK-501 Keys Replacement: stap 5, afbeelding 1 van 1
    • Pull up the top layer of white keys to remove them from the keyboard.
  6. Casio CTK-501 Keys Replacement: stap 6, afbeelding 1 van 1
    • Pull up on the last layer of white keys to remove them.
  7. Casio CTK-501 Keys Replacement: stap 7, afbeelding 1 van 1
    • Push the black keys toward the front of the keyboard and rotate them until they fall out of the keyboard.
Conclusie
7 andere personen hebben deze handleiding voltooid.
Jimmy Winne
578 Reputatie
6 handleidingen geschreven
Cal Poly, Team 9-16, Amido Fall 2012 Lid van Cal Poly, Team 9-16, Amido Fall 2012
CPSU-AMIDO-F12S9G16
4 Leden
4 opmerkingen
my ctk710 keybord circuit failure.... how to get new circuit in online plg help me
michael Akhil - Antwoord
Please do you know where to get Casio CTK700/720 (or compatible) complete Keys set replacement?
Thanks in advance!
Fred from Brasil
Luis Frederico - Antwoord
pliskers@optonline.net
Will replacing keys cure a rattle/chatter that I hear from my middle C and D keys when they are played?
pliskers - Antwoord
I want to repair my Roland Ex 20 keyboard keys because my middle position two keys are muted.
Jit Ghosh - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 36
Altijd: 25,310
