Ga door naar hoofdinhoud
Casdon Dyson Ball On/Off Switch Replacement
Wat je nodig hebt
  1. Casdon Dyson Ball On/Off Switch Replacement, Battery: stap 1, afbeelding 1 van 1
    • Remove one 9.2mm (0.36 in) screw using the PH00 screwdriver.
    • Remove the battery cover by pulling it away from the vacuum once the 9.2mm (0.36 in) screw is removed.
  2. Casdon Dyson Ball On/Off Switch Replacement: stap 2, afbeelding 1 van 1
    • Remove batteries from the vacuum by pulling them out and away from the vacuum.
  3. Casdon Dyson Ball On/Off Switch Replacement, On/Off Switch: stap 3, afbeelding 1 van 1
    • Remove four 9.2mm (0.32 in) screws from the back of the vacuum using the PH00 screwdriver.
  4. Casdon Dyson Ball On/Off Switch Replacement: stap 4, afbeelding 1 van 1
    • Remove the cover to the on/off switch by pulling up on the cover from the front of the vacuum.
  5. Casdon Dyson Ball On/Off Switch Replacement: stap 5, afbeelding 1 van 1
    • Cut the two wires connected to the on/off switch using a set of wire cutters.
  6. Casdon Dyson Ball On/Off Switch Replacement: stap 6, afbeelding 1 van 1
    • Remove the two 9.2mm (0.32 in) screws which hold the on/off switch to the vacuum using the PH00 screwdriver.
  7. Casdon Dyson Ball On/Off Switch Replacement: stap 7, afbeelding 1 van 1
    • Remove the on/off switch by pulling it away from the vacuum with your fingers.
    • Replace the faulty on/off switch with the new on/off switch.
    • Solder the new on/off switch's wires to the vacuum's wires using a soldering station.
Conclusie
Seldon Price
612 Reputatie
5 handleidingen geschreven
IUPUI, Team S3-G5, Harley Fall 2017 Lid van IUPUI, Team S3-G5, Harley Fall 2017
IUPUI-HARLEY-F17S3G5
3 Leden
10 handleidingen geschreven
1Gids Commentaar
Great instructions but where can you purchase the on of switch and what is the part number?
debbyh1024 - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 8
Altijd: 2,219
