Ga door naar hoofdinhoud
Casdon Dyson Ball Disassembly
Wat je nodig hebt
  1. Casdon Dyson Ball Disassembly, Battery: stap 1, afbeelding 1 van 1
    • Remove one 9.2mm (0.36 in) screw using the PH00 screwdriver.
    • Remove the battery cover by pulling it away from the vacuum once the 9.2mm (0.36 in) screw is removed.
  2. Casdon Dyson Ball Disassembly: stap 2, afbeelding 1 van 1
    • Remove batteries from the vacuum by pulling them out and away from the vacuum.
  3. Casdon Dyson Ball Disassembly, Casdon Dyson Ball Disassembly: stap 3, afbeelding 1 van 1
    • Remove all seven 9.2mm (0.32 in) screws on the back of the vacuum.
  4. Casdon Dyson Ball Disassembly: stap 4, afbeelding 1 van 1
    • Remove the front side covers by pulling them away from the vacuum.
  5. Casdon Dyson Ball Disassembly: stap 5, afbeelding 1 van 1
    • Separate the battery compartment from the ball and bead cylinder by sliding the vacuum ball away from the battery compartment.
  6. Casdon Dyson Ball Disassembly: stap 6, afbeelding 1 van 1
    • Separate the bead cylinder and the fan compartment by pulling the bead cylinder away from the fan compartment.
  7. Casdon Dyson Ball Disassembly: stap 7, afbeelding 1 van 1
    • Remove beads from the container.
Conclusie
Seldon Price
612 Reputatie
5 handleidingen geschreven
IUPUI, Team S3-G5, Harley Fall 2017 Lid van IUPUI, Team S3-G5, Harley Fall 2017
IUPUI-HARLEY-F17S3G5
3 Leden
10 handleidingen geschreven
2 opmerkingen
How do I get the handle out once assembled?
Carie McClendon - Antwoord
The fan to make the beads jump around no longer works….is there. Separate battery for that?
Kathy - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 27
Afgelopen 30 dagen: 110
Altijd: 12,438
