Inleiding
By using the PH00 screwdriver, this guide will show how to remove the batteries from the Casdon Dyson Ball.
Wat je nodig hebt
Remove one 9.2mm (0.36 in) screw using the PH00 screwdriver.
Remove the battery cover by pulling it away from the vacuum once the 9.2mm (0.36 in) screw is removed.
Bijna klaar!
Conclusie
3Gids Commentaar
Thank you! Requires 4 (four)āCā batteries yay!
