Ga door naar hoofdinhoud
Casdon Dyson Ball Air Cylinder Motor Replacement
Wat je nodig hebt
  1. Casdon Dyson Ball Air Cylinder Motor Replacement, Battery: stap 1, afbeelding 1 van 1
    • Remove one 9.2mm (0.36 in) screw using the PH00 screwdriver.
    • Remove the battery cover by pulling it away from the vacuum once the 9.2mm (0.36 in) screw is removed.
  2. Casdon Dyson Ball Air Cylinder Motor Replacement: stap 2, afbeelding 1 van 1
    • Remove batteries from the vacuum by pulling them out and away from the vacuum.
  3. Casdon Dyson Ball Air Cylinder Motor Replacement, Casdon Dyson Ball Disassembly: stap 3, afbeelding 1 van 1
    • Remove all seven 9.2mm (0.32 in) screws on the back of the vacuum.
  4. Casdon Dyson Ball Air Cylinder Motor Replacement: stap 4, afbeelding 1 van 1
    • Remove the front side covers by pulling them away from the vacuum.
  5. Casdon Dyson Ball Air Cylinder Motor Replacement: stap 5, afbeelding 1 van 1
    • Separate the battery compartment from the ball and bead cylinder by sliding the vacuum ball away from the battery compartment.
  6. Casdon Dyson Ball Air Cylinder Motor Replacement: stap 6, afbeelding 1 van 1
    • Separate the bead cylinder and the fan compartment by pulling the bead cylinder away from the fan compartment.
  7. Casdon Dyson Ball Air Cylinder Motor Replacement: stap 7, afbeelding 1 van 1
    • Remove beads from the container.
  8. Casdon Dyson Ball Air Cylinder Motor Replacement, Air Cylinder Motor: stap 8, afbeelding 1 van 1
    • Remove four 9.2mm (0.32 in) screws on bottom of air cylinder motor mount using the PH00 screwdriver.
  9. Casdon Dyson Ball Air Cylinder Motor Replacement: stap 9, afbeelding 1 van 1
    • Remove one 11.5mm (0.45 in) screw in battery compartment using the PH00 screwdriver.
  10. Casdon Dyson Ball Air Cylinder Motor Replacement: stap 10, afbeelding 1 van 1
    • Remove the red fan from the motor by pulling the red fan away from the bead cylinder motor compartment.
  11. Casdon Dyson Ball Air Cylinder Motor Replacement: stap 11, afbeelding 1 van 1
    • Cut wires connected to faulty motor using a set of wire cutters.
  12. Casdon Dyson Ball Air Cylinder Motor Replacement: stap 12, afbeelding 1 van 2 Casdon Dyson Ball Air Cylinder Motor Replacement: stap 12, afbeelding 2 van 2
    • Remove and replace faulty air cylinder motor.
    • Solder new air cylinder motor's wires to the vacuum's wires which were previously cut.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Seldon Price
612 Reputatie
5 handleidingen geschreven
IUPUI, Team S3-G5, Harley Fall 2017 Lid van IUPUI, Team S3-G5, Harley Fall 2017
IUPUI-HARLEY-F17S3G5
3 Leden
10 handleidingen geschreven
Één opmerking
What motor is it?
Daniel Blakey - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 9
Altijd: 312
