Ga door naar hoofdinhoud
Carrier P4SPA6 Home Air Filter Replacement
Wat je nodig hebt
  1. Carrier P4SPA6 Home Air Filter Replacement, Air Filter: stap 1, afbeelding 1 van 1
    • Turn off the HVAC system to prevent unfiltered air from traveling through your home.
    • Usually the button for the system is located besides your AC. If not, adjust the temperature setting lower than the current room temperature to trigger the system to turn off.
    • Wait for 5 mins to fully shut down. Check the fan before you start.
  2. Carrier P4SPA6 Home Air Filter Replacement: stap 2, afbeelding 1 van 1
    • The air filter compartment is usually near the air duct. Depending on your individual system, you may find it near the furnace. Based on how your system is set up, you may need a screwdriver to open the cover in order to access your old air filter.
  3. Carrier P4SPA6 Home Air Filter Replacement: stap 3, afbeelding 1 van 1
    • Slide out your old filter but pay attention to the direction of airflow indicated on the box. If you can’t find it, the airflow should go towards the furnace. Proper disposal is important because it will usually contain dust and debris. Use a vacuum or a cloth to wipe away dirt and clean up debris if you can.
  4. Carrier P4SPA6 Home Air Filter Replacement: stap 4, afbeelding 1 van 1
    • Take the new air filter and insert it into the slot, following the direction of the airflow arrow on the filter frame, making sure it's snug.
    • If it's loose, check the size. There should be a place to put the date on top but this sub step is optional.
  5. Carrier P4SPA6 Home Air Filter Replacement: stap 5, afbeelding 1 van 1
    • Close the compartment by putting on the cover. You may need a screwdriver. Double check that it is sealed properly before turning on the HVAC system.
    • If you can’t access the button, trigger it by adjusting the temperature. In the summer, lower the temperature below the room temperature. In the winter increase it above the room temperature.
Conclusie
This step-by-step guide aims to raise awareness about the importance of regular air filter replacement and provide clear instructions for a successful replacement process.
Shovon Roy
121 Reputatie
1 Handleiding geschreven
York University, Team M-8, Allen Summer 2023 Lid van York University, Team M-8, Allen Summer 2023
YORK-ALLEN-SU23SMG8
2 Leden
1 handleiding geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 15
Altijd: 87
