Ga door naar hoofdinhoud
Carrier 58MSA060-08 Furnace Filter Replacement
Wat je nodig hebt
  1. Carrier 58MSA060-08 Furnace Filter Replacement, Furnace Filter: stap 1, afbeelding 1 van 2 Carrier 58MSA060-08 Furnace Filter Replacement, Furnace Filter: stap 1, afbeelding 2 van 2
    • Locate the furnace disconnect switch.
    • Flip the switch from the "ON" position to the "OFF" position.
  2. Carrier 58MSA060-08 Furnace Filter Replacement: stap 2, afbeelding 1 van 1
    • The filter is located in between the return duct and the main furnace unit.
  3. Carrier 58MSA060-08 Furnace Filter Replacement: stap 3, afbeelding 1 van 3 Carrier 58MSA060-08 Furnace Filter Replacement: stap 3, afbeelding 2 van 3 Carrier 58MSA060-08 Furnace Filter Replacement: stap 3, afbeelding 3 van 3
    • Pull the filter cover off of the duct to remove it and expose the filter.
  4. Carrier 58MSA060-08 Furnace Filter Replacement: stap 4, afbeelding 1 van 2 Carrier 58MSA060-08 Furnace Filter Replacement: stap 4, afbeelding 2 van 2
    • Examine your furnace to determine the air flow direction.
    • The Return Duct
    • The Furnace Unit
    • The air will always flow from the return duct towards the furnace unit.
    • Your old filter may also have an arrow indicator on the side.
    • The arrow's direction will indicate the air flow direction.
  5. Carrier 58MSA060-08 Furnace Filter Replacement: stap 5, afbeelding 1 van 3 Carrier 58MSA060-08 Furnace Filter Replacement: stap 5, afbeelding 2 van 3 Carrier 58MSA060-08 Furnace Filter Replacement: stap 5, afbeelding 3 van 3
    • Remove the old filter by pulling it out of the duct.
  6. Carrier 58MSA060-08 Furnace Filter Replacement: stap 6, afbeelding 1 van 3 Carrier 58MSA060-08 Furnace Filter Replacement: stap 6, afbeelding 2 van 3 Carrier 58MSA060-08 Furnace Filter Replacement: stap 6, afbeelding 3 van 3
    • Insert the new filter.
    • Pay attention to which direction the new filter should face before inserting it; make it is correct.
  7. Carrier 58MSA060-08 Furnace Filter Replacement: stap 7, afbeelding 1 van 2 Carrier 58MSA060-08 Furnace Filter Replacement: stap 7, afbeelding 2 van 2
    • Reattach the filter cover.
    • Ensure that the filter cover is securely in place.
  8. Carrier 58MSA060-08 Furnace Filter Replacement: stap 8, afbeelding 1 van 2 Carrier 58MSA060-08 Furnace Filter Replacement: stap 8, afbeelding 2 van 2
    • Turn on the furnace.
    • Flip the switch from the "OFF" position to the "ON" position.
Conclusie
Once you have completed these steps, your furnace filter replacement will be complete.
Alexander Ye
184 Reputatie
1 Handleiding geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 19
Afgelopen 30 dagen: 123
Altijd: 5,834
