Ga door naar hoofdinhoud
Carrera Mario Kart 8 Peach Axle Replacement Guide Replacement
Wat je nodig hebt
  1. Carrera Mario Kart 8 Peach Axle Replacement Guide Replacement, Axle Replacement Guide: stap 1, afbeelding 1 van 1
    • Flip the car with the bottom side facing up.
    • Using a Philips screwdriver, remove the middle screw on the front axle while holding it the axle in place.
    • Carefully place the screw in a magnetic pad (or somewhere you won’t loose)
  2. Carrera Mario Kart 8 Peach Axle Replacement Guide Replacement: stap 2, afbeelding 1 van 1
    • Place the new axle where on the curved side is pointed towards center.
    • Screw it into place but make sure it isn't too tight. The axle needs to able to move a bit.
  3. Carrera Mario Kart 8 Peach Axle Replacement Guide Replacement: stap 3, afbeelding 1 van 1
    • Repeat the same steps for the back axle of the car but without concern of the curved part.
  4. Carrera Mario Kart 8 Peach Axle Replacement Guide Replacement: stap 4, afbeelding 1 van 1
    • Place the new wheel into the car and attach the new screw
Conclusie
Kimberly Santos
331 Reputatie
3 handleidingen geschreven
USF Tampa, Team S3-G5, Cannon Fall 2017 Lid van USF Tampa, Team S3-G5, Cannon Fall 2017
USFT-CANNON-F17S3G5
4 Leden
10 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 13
Altijd: 804
