Inleiding
The motherboard is an essential part of the Mario copter, without it the copter does not work. if it is damage or broken, this guide will show you how to remove it properly.
Wat je nodig hebt
Flip the quadrocopter over so that the underside of the device is facing up.
Unplug the battery cable from the socket on the quadrocopter.
Using the Phillips # PH00 screwdriver unscrew the four 7.1mm screws in the black circle base.
Remove the entire black circle base and flip it over so you can see the motherboard.
Één andere persoon heeft deze handleiding voltooid.
