Ga door naar hoofdinhoud
Cardo Packtalk Battery Replacement
Wat je nodig hebt
  1. Cardo Packtalk Battery Replacement, Remove Case Screws: stap 1, afbeelding 1 van 1
    • Insert wisdom here.
    Vraag FixBot
  2. Cardo Packtalk Battery Replacement, Open Case Carfully: stap 2, afbeelding 1 van 1
    • Take lower section off first, take care not to strain the battery wires
    Vraag FixBot
    • Some people simply cut the old battery wires and heat shrink them to new battery wires to avoid having to re-solder the small solder points on the PCB.
    Vraag FixBot
    Vraag FixBot
    • If you want to ensure your unit stays waterproof, you can add a thin line of silicone seal around case prior to reassembly
    Vraag FixBot
    Vraag FixBot
    Vraag FixBot
Conclusie
FJrider
300 Reputatie
1 Handleiding geschreven
2Gids Commentaar
Can you recommend a battery to purchase for the Packtalk BOLD? Thanks!
Tony Psaltis - Antwoord Deel
I can't recommend a particular one, when my Smartpack battery died I cannibalized an OEM battery from a broken Packtalk unit.
Here are a couple batteries on offer from Ebay and Amazon that claim they fit the Packtalk and have some good reviews (do your own research):
-https://www.ebay.com/itm/156144503815?mk...
-https://a.co/d/fuu9s9K
FJrider - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 8
Afgelopen 7 dagen: 61
Afgelopen 30 dagen: 323
Altijd: 4,153
