Inleiding
The Turbine is integral to the Ventilator's function. A possible cause of failure during the delivered volume test is the turbine assembly itself. In this case the Turbine assembly must be removed, and either replaced with P/N 16349 or sent to manufacturer for Re-Characterization. This guide will walk through the necessary steps to remove the turbine assembly.
Wat je nodig hebt
Stap 1 Cardinal Health Vela Ventilator Power Cable Removal
Voorzichtig: stappen 1-2 komen van een handleiding die in bewerking is.
Use a screwdriver to remove the two Phillips pan-head screws at the top of the plug guard.
Remove the four Phillips #0 screws on the back side of the ventilator.
Stap 6 Cardinal Health Vela Ventilator Battery Tray Removal
Voorzichtig: stappen 6-8 komen van een handleiding die in bewerking is.
Use your Phillips screwdriver to unscrew the 4 Phillips pan head screws positioned on each side of the battery tray.
Stap 13 Blender Assembly P/N 16358A
Voorzichtig: stappen 13-21 komen van een handleiding die in bewerking is.
If the rear panel is installed, remove the high and low pressure oxygen fittings from the rear panel using your 3/4" wrench. NOTE: the high pressure fitting is located above the low pressure fitting
Disconnect the main wire harness connector at P2 on the Turbine Driver PCBA
Één andere persoon heeft deze handleiding voltooid.
