Ga door naar hoofdinhoud
Cardinal Health Vela Ventilator Left Panel Replacement
Medische apparatuur
Noch iFixit, noch deze reparatiehandleiding worden onderschreven door of zijn gelieerd aan de fabrikant van de desbetreffende medische apparatuur.
Wat je nodig hebt
  1. Voorzichtig: stappen 1-2 komen van een handleiding die in bewerking is.
    Cardinal Health Vela Ventilator Left Panel Replacement, Cardinal Health Vela Ventilator Power Cable Removal: stap 1, afbeelding 1 van 1
    • Use a screwdriver to remove the two Phillips pan-head screws at the top of the plug guard.
    • Remove the plug guard and unplug the ventilator.
  2. Cardinal Health Vela Ventilator Left Panel Replacement, Cardinal Health Vela Ventilator Top Cover Disassembly: stap 3, afbeelding 1 van 1
    • Remove the four Phillips #0 screws on the back side of the ventilator.
  3. Cardinal Health Vela Ventilator Left Panel Replacement: stap 4, afbeelding 1 van 1
    • Remove all six small side panel screws along the bottom of each side of the top cover with the same screwdriver.
    • Slide the top cover towards the back side of the ventilator to remove it.
  4. Voorzichtig: stappen 6-8 komen van een handleiding die in bewerking is.
    Cardinal Health Vela Ventilator Left Panel Replacement, Cardinal Health Vela Ventilator Battery Tray Removal: stap 6, afbeelding 1 van 1
    • Use your Phillips screwdriver to unscrew the 4 Phillips pan head screws positioned on each side of the battery tray.
    • Lift the battery tray out of the ventilator.
    • Caution: The wires connecting the batteries to the ventilator will still be connected so lift the battery tray carefully.
  5. Cardinal Health Vela Ventilator Left Panel Replacement: stap 8, afbeelding 1 van 1
    • Disconnect the batteries from the ventilator by pulling apart the Battery Connector.
    • Remove the two Phillips countersink at the rear of the panel.
    • Remove the Phillips countersink in the upper front of the panel.
    • The panel is now free and can be lifted from the device.
    • To install the left panel follow these steps in reverse order.
Conclusie
Tanner Hillman
370 Reputatie
3 handleidingen geschreven
Cal Poly, Team S7-G22, Paton Spring 2020 Lid van Cal Poly, Team S7-G22, Paton Spring 2020
CPSU-PATON-S20S7G22
1 Lid
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 5
Altijd: 107
