Ga door naar hoofdinhoud
Carburetor Cleaning
Wat je nodig hebt
  1. Carburetor Cleaning, Air Filter: stap 1, afbeelding 1 van 3 Carburetor Cleaning, Air Filter: stap 1, afbeelding 2 van 3 Carburetor Cleaning, Air Filter: stap 1, afbeelding 3 van 3
    • Before starting, ensure that the engine is not running and is not hot.
    • Pull the tab until the filter cover opens. Remove the filter cover.
    • Note that the bottom of the cover is hinged.
  2. Carburetor Cleaning: stap 2, afbeelding 1 van 1
    • Remove the air filter.
    • The air filter will be either an oily sponge, or an accordion-folded fabric.
    • Note that the air filter is saturated with oil. Wear gloves and use paper towels to avoid creating a mess.
  3. Carburetor Cleaning, Carburetor Cleaning: stap 3, afbeelding 1 van 3 Carburetor Cleaning, Carburetor Cleaning: stap 3, afbeelding 2 van 3 Carburetor Cleaning, Carburetor Cleaning: stap 3, afbeelding 3 van 3
    • Locate the four bolts holding the air filter housing to the engine. Remove these bolts using the ratchet driver and the appropriately sized socket.
    • Remove the 1/4" bolts.
    • Remove the 5/16" bolts.
  4. Carburetor Cleaning: stap 4, afbeelding 1 van 2 Carburetor Cleaning: stap 4, afbeelding 2 van 2
    • Lift away the air filter housing.
    • Note that the housing is still attached to the engine via a bendable plastic rod.
  5. Carburetor Cleaning: stap 5, afbeelding 1 van 1
    • Spray carburetor cleaner into the open carburetor.
    • You may want to wear gloves for this step, as carburetor cleaner is harmful if applied to the skin.
Conclusie
Ethan Narad
529 Reputatie
3 handleidingen geschreven
Cal Poly, Team S25-G15, Maness Spring 2018 Lid van Cal Poly, Team S25-G15, Maness Spring 2018
CPSU-MANESS-S18S25G15
4 Leden
7 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 2
Altijd: 1,669
