Inleiding
Follow this guide to adjust the carburetor on a 2019 Echo Power Pruner model PPT-2620.
This procedure requires running the motor for several minutes. Only run the motor outside or in a large, well-ventilated room. Do not run the motor in an enclosed space.
Wear ear protection while the motor is running.
Wat je nodig hebt
Feed the inductive pickup lead wire through one of the two holes in the lower-left corner of the tachometer.
Bend the wire around and feed it through the second hole, then pull it tight.
Clamp the inductive pickup lead alligator clip onto the spark plug wire.
Start the motor and let it run for two minutes to ensure it reaches operating temperature.
The procedure is complete, no further action is required.
