Ga door naar hoofdinhoud
Car Seat Belt Stopper Replacement
Wat je nodig hebt
  1. Car Seat Belt Stopper Replacement, Car Seat Belt Stopper: stap 1, afbeelding 1 van 1
    • Use a cloth to wipe away any debris from the area.
    Vraag FixBot
    Voeg opmerking toe
  2. Car Seat Belt Stopper Replacement: stap 2, afbeelding 1 van 1
    • Find the existing hole for the seat belt stopper or choose a different location that is better for you.
    • Separate the replacement stopper if it has come assembled.
    Vraag FixBot
    Voeg opmerking toe
  3. Car Seat Belt Stopper Replacement: stap 3, afbeelding 1 van 1
    • Before you begin, make sure that the seat belt buckle is pushed above the hole where you are installing the new seat belt stopper.
    • Push the side of the seat belt button with the needle or point into your desired location.
    • It may require a small amount of force.
    Vraag FixBot
    Voeg opmerking toe
  4. Car Seat Belt Stopper Replacement: stap 4, afbeelding 1 van 1
    • Take the other half of button stopper and slide it onto the pin on the other side of the belt.
    • Fasten the two parts of the button together and squeeze for a secure fit.
    • You may hear a "snap" or "click" when they are fastened together.
    Vraag FixBot
    Voeg opmerking toe
  5. Car Seat Belt Stopper Replacement: stap 5, afbeelding 1 van 1
    • Check the position of the replacement stopper for a comfortable fit.
    Vraag FixBot
    Voeg opmerking toe
  6. Car Seat Belt Stopper Replacement: stap 6, afbeelding 1 van 1
    • Now you can use the seat belt buckle without it falling down!
    Vraag FixBot
    Voeg opmerking toe
Conclusie
Changing your positioning of replacement can be used to your liking.
Één andere persoon heeft deze handleiding voltooid.
Zhong Chu
137 Reputatie
1 Handleiding geschreven
UC Davis, Team 4-1, Whithaus Spring 2024 Lid van UC Davis, Team 4-1, Whithaus Spring 2024
UCD-WHITHAUS-S24S4G1
3 Leden
1 handleiding geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 19
Afgelopen 30 dagen: 154
Altijd: 3,089
