Ga door naar hoofdinhoud
Capresso Perfectea 260 Motherboard Replacement
Wat je nodig hebt
  1. Capresso Perfectea 260 Motherboard Replacement, Motherboard: stap 1, afbeelding 1 van 1
    • First, take the base of the device and flip it over.
  2. Capresso Perfectea 260 Motherboard Replacement: stap 2, afbeelding 1 van 2 Capresso Perfectea 260 Motherboard Replacement: stap 2, afbeelding 2 van 2
    • Remove the four 12 mm Phillips #2 screws surrounding the base then lift the bottom half of the base to expose the circuit boards inside the device.
  3. Capresso Perfectea 260 Motherboard Replacement: stap 3, afbeelding 1 van 1
    • Remove the two 7.5 mm Phillips #2 screws holding in the motherboard
  4. Capresso Perfectea 260 Motherboard Replacement: stap 4, afbeelding 1 van 1
    • Unplug the wire going into the side of the motherboard
  5. Capresso Perfectea 260 Motherboard Replacement: stap 5, afbeelding 1 van 2 Capresso Perfectea 260 Motherboard Replacement: stap 5, afbeelding 2 van 2
    • Use the metal spudger to cut open the rubber covering the latch where it clamps onto the copper tab.
    • Unplug wire at heating element by first using the metal spudger to push the latch in and then pushing it out.
    • Be careful when unplugging the wire as if it is done too forcefully it can damage the connection and make it difficult to connect a new motherboard
  6. Capresso Perfectea 260 Motherboard Replacement: stap 6, afbeelding 1 van 1
    • Lift the motherboard out of the device
Conclusie
Rohin Chander
101 Reputatie
1 Handleiding geschreven
Cal Poly, Team 6-17, Maness Spring 2015 Lid van Cal Poly, Team 6-17, Maness Spring 2015
CPSU-MANESS-S15S6G17
4 Leden
6 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 9
Altijd: 236
