Ga door naar hoofdinhoud
Capresso Infinity Timer/On Switch Replacement
Wat je nodig hebt
  1. Capresso Infinity Timer/On Switch Replacement, Metal Outside Casing: stap 1, afbeelding 1 van 2 Capresso Infinity Timer/On Switch Replacement, Metal Outside Casing: stap 1, afbeelding 2 van 2
    • Twist the top plastic container to the left counterclockwise.
    • Pull upwards to remove.
  2. Capresso Infinity Timer/On Switch Replacement: stap 2, afbeelding 1 van 3 Capresso Infinity Timer/On Switch Replacement: stap 2, afbeelding 2 van 3 Capresso Infinity Timer/On Switch Replacement: stap 2, afbeelding 3 van 3
    • Twist the top burr to the left counter clockwise.
  3. Capresso Infinity Timer/On Switch Replacement: stap 3, afbeelding 1 van 2 Capresso Infinity Timer/On Switch Replacement: stap 3, afbeelding 2 van 2
    • Flip entire device upside down.
    • Remove two rubber coverings on the back of the device.
  4. Capresso Infinity Timer/On Switch Replacement: stap 4, afbeelding 1 van 2 Capresso Infinity Timer/On Switch Replacement: stap 4, afbeelding 2 van 2
    • Remove four 11.59mm T10 screws.
    • The screws will have small circular washers under them. Put them aside for reassembly.
  5. Capresso Infinity Timer/On Switch Replacement: stap 5, afbeelding 1 van 3 Capresso Infinity Timer/On Switch Replacement: stap 5, afbeelding 2 van 3 Capresso Infinity Timer/On Switch Replacement: stap 5, afbeelding 3 van 3
    • Lift the metal outside casing off the black base.
    • Flip the outside casing forward so you have access to the inside of it.
  6. Capresso Infinity Timer/On Switch Replacement: stap 6, afbeelding 1 van 3 Capresso Infinity Timer/On Switch Replacement: stap 6, afbeelding 2 van 3 Capresso Infinity Timer/On Switch Replacement: stap 6, afbeelding 3 van 3
    • Remove one 11.59mm T10 screw.
    • Let the green wire fall, or place somewhere so it doesn't get in the way.
    • There will be a small metal retainer and washer, put them aside for reassembly.
  7. Capresso Infinity Timer/On Switch Replacement: stap 7, afbeelding 1 van 3 Capresso Infinity Timer/On Switch Replacement: stap 7, afbeelding 2 van 3 Capresso Infinity Timer/On Switch Replacement: stap 7, afbeelding 3 van 3
    • Remove two 11.59mm T10 screws.
  8. Capresso Infinity Timer/On Switch Replacement: stap 8, afbeelding 1 van 2 Capresso Infinity Timer/On Switch Replacement: stap 8, afbeelding 2 van 2
    • Remove the time/on switch by pulling upwards.
  9. Capresso Infinity Timer/On Switch Replacement, Timer/On Switch: stap 9, afbeelding 1 van 1
    • Strip the two wires of their black covering connecting them to the black box.
  10. Capresso Infinity Timer/On Switch Replacement: stap 10, afbeelding 1 van 3 Capresso Infinity Timer/On Switch Replacement: stap 10, afbeelding 2 van 3 Capresso Infinity Timer/On Switch Replacement: stap 10, afbeelding 3 van 3
    • Solder the two cords holding in the blue and white wire in the black timer box.
Conclusie
3 andere personen hebben deze handleiding voltooid.
Melayne Spataro
272 Reputatie
1 Handleiding geschreven
USF Tampa, Team S1-G1, Leahy Fall 2018 Lid van USF Tampa, Team S1-G1, Leahy Fall 2018
USFT-LEAHY-F18S1G1
4 Leden
10 handleidingen geschreven
7Gids Commentaar
do you know where I can get a new black timer box?
geclay@hotmail.com - Antwoord
Where can I purchase a timer/on switch?
Rob Gordon - Antwoord
Same question here, where can I buy this part?
Dominic Daigle - Antwoord
Just piling on,has anyone found where to buy the Timer switch?
Chris DiNicolas - Antwoord
Same, looking for part number and/or where to buy the timer dial.
Hans Sorensen - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 20
Afgelopen 30 dagen: 76
Altijd: 3,252
