Ga door naar hoofdinhoud
Canon ZR70MC Front Panel Replacement
Wat je nodig hebt
  1. Canon ZR70MC Front Panel Replacement, Front Panel: stap 1, afbeelding 1 van 2 Canon ZR70MC Front Panel Replacement, Front Panel: stap 1, afbeelding 2 van 2
    • Unscrew the 3.35mm screw.
  2. Canon ZR70MC Front Panel Replacement: stap 2, afbeelding 1 van 1
    • Turn the ZR70MC so that you can see the bottom of the camcorder.
    • Unscrew the 3.35 mm located in the top left portion of the camera.
  3. Canon ZR70MC Front Panel Replacement: stap 3, afbeelding 1 van 3 Canon ZR70MC Front Panel Replacement: stap 3, afbeelding 2 van 3 Canon ZR70MC Front Panel Replacement: stap 3, afbeelding 3 van 3
    • Turn the camera on the side and remove the cover for the audio inputs. There is a 2.65 mm screw located behind the cover.
    • Remove the 2.65 mm screw.
  4. Canon ZR70MC Front Panel Replacement: stap 4, afbeelding 1 van 3 Canon ZR70MC Front Panel Replacement: stap 4, afbeelding 2 van 3 Canon ZR70MC Front Panel Replacement: stap 4, afbeelding 3 van 3
    • Remove the cover located on the front of the camcorder and remove the cover by pulling on the bottom groove.
    • Locate and remove the two 3.35 mm screws.
  5. Canon ZR70MC Front Panel Replacement: stap 5, afbeelding 1 van 2 Canon ZR70MC Front Panel Replacement: stap 5, afbeelding 2 van 2
    • Turn the camcorder so that the bottom is facing up and open the tape cassette compartment.
    • There is one 3.35 mm screw located under the tape cassette panel on the front left side of the camcorder. Remove the screw.
  6. Canon ZR70MC Front Panel Replacement: stap 6, afbeelding 1 van 3 Canon ZR70MC Front Panel Replacement: stap 6, afbeelding 2 van 3 Canon ZR70MC Front Panel Replacement: stap 6, afbeelding 3 van 3
    • Now that all of the screws are removed, remove the front panel by gently pulling on the front panel.
    • The speaker will be connected to the main body by a wire. Be careful not to damage this wire.
  7. Canon ZR70MC Front Panel Replacement: stap 7, afbeelding 1 van 3 Canon ZR70MC Front Panel Replacement: stap 7, afbeelding 2 van 3 Canon ZR70MC Front Panel Replacement: stap 7, afbeelding 3 van 3
    Gereedschap gebruikt in deze stap:
    Koop
    • Use tweezers to gently pull the speaker wire from the main body of the camcorder.
    • Pull the front panel completely away from the main body of the camcorder.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
khalid clarke
824 Reputatie
7 handleidingen geschreven
USF Tampa, Team S13-G2, Boczar Fall 2017 Lid van USF Tampa, Team S13-G2, Boczar Fall 2017
USFT-BOCZAR-F17S13G2
3 Leden
14 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 4
Altijd: 200
