Ga door naar hoofdinhoud
Canon Vixia HF20 Camcorder Strap Replacement
  1. Canon Vixia HF20 Camcorder Strap Replacement, Camcorder Strap: stap 1, afbeelding 1 van 3 Canon Vixia HF20 Camcorder Strap Replacement, Camcorder Strap: stap 1, afbeelding 2 van 3 Canon Vixia HF20 Camcorder Strap Replacement, Camcorder Strap: stap 1, afbeelding 3 van 3
    • Un-velcro the camcorder strap.
    • Remove the strap from the first hole by pulling towards the front of the camcorder, continue pulling the strap through until it is removed from second anchor point as well.
    • There should now be two empty anchor points.
  2. Canon Vixia HF20 Camcorder Strap Replacement: stap 2, afbeelding 1 van 3 Canon Vixia HF20 Camcorder Strap Replacement: stap 2, afbeelding 2 van 3 Canon Vixia HF20 Camcorder Strap Replacement: stap 2, afbeelding 3 van 3
    • Re-insert the new Velcro strap through the back anchor hole in the direction of the arrow (toward the battery end of the camcorder).
    • Then through the padded hand strap in direction of the arrow.
    • Lastly, pull the strap through the front anchor hole adjusting for your grip.
  3. Canon Vixia HF20 Camcorder Strap Replacement: stap 3, afbeelding 1 van 1
    • Once the fit is adjusted, secure by closing the padded strap.
Eindstreep
Één andere persoon heeft deze handleiding voltooid.
Taylor Morris
225 Reputatie
2 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 16
Afgelopen 30 dagen: 27
Altijd: 641
