Ga door naar hoofdinhoud
Canon Vixia HF S10 Camcorder Audio Replacement
Wat je nodig hebt
  1. Canon Vixia HF S10 Camcorder Audio Replacement, Audio: stap 1, afbeelding 1 van 3 Canon Vixia HF S10 Camcorder Audio Replacement, Audio: stap 1, afbeelding 2 van 3 Canon Vixia HF S10 Camcorder Audio Replacement, Audio: stap 1, afbeelding 3 van 3
    • Turn the camcorder upside down and remove the three 3x4 mm Phillips screws securing the black plastic case.
    • Flip open the LCD screen.
    • Remove the three 3x4 mm Phillips screws securing the black panel plastic case.
  2. Canon Vixia HF S10 Camcorder Audio Replacement: stap 2, afbeelding 1 van 3 Canon Vixia HF S10 Camcorder Audio Replacement: stap 2, afbeelding 2 van 3 Canon Vixia HF S10 Camcorder Audio Replacement: stap 2, afbeelding 3 van 3
    • From the inner corner in between the panel and the LCD screen, remove the two 2x2.5 mm Phillips screws and the 3x4 mm Phillips screw.
    • Remove the black plastic covering with your fingers. Underneath the covering, you will find a screw hinge.
    • Remove the 2x2.25 mm Phillips screw located at the top of the screw hinge.
  3. Canon Vixia HF S10 Camcorder Audio Replacement: stap 3, afbeelding 1 van 3 Canon Vixia HF S10 Camcorder Audio Replacement: stap 3, afbeelding 2 van 3 Canon Vixia HF S10 Camcorder Audio Replacement: stap 3, afbeelding 3 van 3
    • Using your fingers, remove the panel from the base of the camcorder.
    • After removing the panel, remove the two 2x2.25 mm Phillips screws located at the top right of the inside of the panel.
    • Using one hand, gently move the silver piece holding the speaker down while using the other hand to remove the speaker.
Conclusie
Clint
101 Reputatie
1 Handleiding geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 13
Altijd: 420
