Ga door naar hoofdinhoud
Canon Vixia HF R500 Zoom Control Replacement
Wat je nodig hebt
  1. Canon Vixia HF R500 Zoom Control  Replacement, Grip Belt: stap 1, afbeelding 1 van 3 Canon Vixia HF R500 Zoom Control  Replacement, Grip Belt: stap 1, afbeelding 2 van 3 Canon Vixia HF R500 Zoom Control  Replacement, Grip Belt: stap 1, afbeelding 3 van 3
    • On the right side of the camcorder remove the grip belt.
  2. Canon Vixia HF R500 Zoom Control  Replacement, Battery: stap 2, afbeelding 1 van 1
    • Hold on to the battery.
  3. Canon Vixia HF R500 Zoom Control  Replacement: stap 3, afbeelding 1 van 1
    • On the bottom of the battery hold the battery release switch.
  4. Canon Vixia HF R500 Zoom Control  Replacement: stap 4, afbeelding 1 van 1
    • Remove the battery slowly away from the camcorder.
    • Removing the battery quick or in a different angle may cause sparks and damage to device.
  5. Canon Vixia HF R500 Zoom Control  Replacement, Canon Vixia HF R500 Disassembly: stap 5, afbeelding 1 van 2 Canon Vixia HF R500 Zoom Control  Replacement, Canon Vixia HF R500 Disassembly: stap 5, afbeelding 2 van 2
    • Remove the two 8mm Philips #000 screws on the side where the grip belt was located on.
  6. Canon Vixia HF R500 Zoom Control  Replacement: stap 6, afbeelding 1 van 1
    • Remove the two 4mm Philips #000 head screws from the bottom of the camcorder.
    • A hidden 4mm Philips #000 screw is shown under the black plug shown.
  7. Canon Vixia HF R500 Zoom Control  Replacement: stap 7, afbeelding 1 van 1
    • Remove the side piece plate.
  8. Canon Vixia HF R500 Zoom Control  Replacement: stap 8, afbeelding 1 van 1
    • Near the LCD screen, remove the three 7mm Philips #000 screws in the picture shown.
  9. Canon Vixia HF R500 Zoom Control  Replacement: stap 9, afbeelding 1 van 1
    • Carefully place the camcorder where the inside of the device is facing upwards and remove the 3mm Philips #000 screw shown.
    • Do not use strong magnetic parts on the inside, as they may damage the device.
  10. Canon Vixia HF R500 Zoom Control  Replacement: stap 10, afbeelding 1 van 1
    • Using the spudger, pull the tab shown to start removing the ribbon cable.
  11. Canon Vixia HF R500 Zoom Control  Replacement: stap 11, afbeelding 1 van 3 Canon Vixia HF R500 Zoom Control  Replacement: stap 11, afbeelding 2 van 3 Canon Vixia HF R500 Zoom Control  Replacement: stap 11, afbeelding 3 van 3
    • Using the Spudger, carefully remove the two ribbon cables that are connected to the top of the device.
  12. Canon Vixia HF R500 Zoom Control  Replacement: stap 12, afbeelding 1 van 1
    • Remove the top piece.
  13. Canon Vixia HF R500 Zoom Control  Replacement, Speaker: stap 13, afbeelding 1 van 2 Canon Vixia HF R500 Zoom Control  Replacement, Speaker: stap 13, afbeelding 2 van 2
    • Remove the three 6mm Philips #000 screws holding the black record piece.
  14. Canon Vixia HF R500 Zoom Control  Replacement: stap 14, afbeelding 1 van 1
    • Remove the black record piece.
  15. Canon Vixia HF R500 Zoom Control  Replacement: stap 15, afbeelding 1 van 2 Canon Vixia HF R500 Zoom Control  Replacement: stap 15, afbeelding 2 van 2
    • Holding the full top piece remove the six 5mm Philips #000 screws holding the metal frame to the top piece.
  16. Canon Vixia HF R500 Zoom Control  Replacement: stap 16, afbeelding 1 van 1
    • Carefully remove the the whole metal frame out of the device piece.
  17. Canon Vixia HF R500 Zoom Control  Replacement: stap 17, afbeelding 1 van 1
    • Replace the defective speaker with a functioning one.
  18. Canon Vixia HF R500 Zoom Control  Replacement, Zoom Control: stap 18, afbeelding 1 van 2 Canon Vixia HF R500 Zoom Control  Replacement, Zoom Control: stap 18, afbeelding 2 van 2
    • Examine the grey zoom input tab located on copper plate.
    • Examine the black plastic zoom slider, on the top cover of the camera
    • Repair or replace damaged components and clear all debris from mechanisms.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 9
Altijd: 250
