Ga door naar hoofdinhoud
Canon Vixia HF R500 Lens Cover Replacement
Wat je nodig hebt
  1. Canon Vixia HF R500 Lens Cover Replacement, Grip Belt: stap 1, afbeelding 1 van 3 Canon Vixia HF R500 Lens Cover Replacement, Grip Belt: stap 1, afbeelding 2 van 3 Canon Vixia HF R500 Lens Cover Replacement, Grip Belt: stap 1, afbeelding 3 van 3
    • On the right side of the camcorder remove the grip belt.
  2. Canon Vixia HF R500 Lens Cover Replacement, Battery: stap 2, afbeelding 1 van 1
    • Hold on to the battery.
  3. Canon Vixia HF R500 Lens Cover Replacement: stap 3, afbeelding 1 van 1
    • On the bottom of the battery hold the battery release switch.
  4. Canon Vixia HF R500 Lens Cover Replacement: stap 4, afbeelding 1 van 1
    • Remove the battery slowly away from the camcorder.
    • Removing the battery quick or in a different angle may cause sparks and damage to device.
  5. Canon Vixia HF R500 Lens Cover Replacement, Canon Vixia HF R500 Disassembly: stap 5, afbeelding 1 van 2 Canon Vixia HF R500 Lens Cover Replacement, Canon Vixia HF R500 Disassembly: stap 5, afbeelding 2 van 2
    • Remove the two 8mm Philips #000 screws on the side where the grip belt was located on.
  6. Canon Vixia HF R500 Lens Cover Replacement: stap 6, afbeelding 1 van 1
    • Remove the two 4mm Philips #000 head screws from the bottom of the camcorder.
    • A hidden 4mm Philips #000 screw is shown under the black plug shown.
  7. Canon Vixia HF R500 Lens Cover Replacement: stap 7, afbeelding 1 van 1
    • Remove the side piece plate.
  8. Canon Vixia HF R500 Lens Cover Replacement: stap 8, afbeelding 1 van 1
    • Near the LCD screen, remove the three 7mm Philips #000 screws in the picture shown.
  9. Canon Vixia HF R500 Lens Cover Replacement: stap 9, afbeelding 1 van 1
    • Carefully place the camcorder where the inside of the device is facing upwards and remove the 3mm Philips #000 screw shown.
    • Do not use strong magnetic parts on the inside, as they may damage the device.
  10. Canon Vixia HF R500 Lens Cover Replacement: stap 10, afbeelding 1 van 1
    • Using the spudger, pull the tab shown to start removing the ribbon cable.
  11. Canon Vixia HF R500 Lens Cover Replacement: stap 11, afbeelding 1 van 3 Canon Vixia HF R500 Lens Cover Replacement: stap 11, afbeelding 2 van 3 Canon Vixia HF R500 Lens Cover Replacement: stap 11, afbeelding 3 van 3
    • Using the Spudger, carefully remove the two ribbon cables that are connected to the top of the device.
  12. Canon Vixia HF R500 Lens Cover Replacement: stap 12, afbeelding 1 van 1
    • Remove the top piece.
  13. Canon Vixia HF R500 Lens Cover Replacement, Lens Cover: stap 13, afbeelding 1 van 1
    • Remove the two 5mm Phillips #000 screws near the LCD screen.
  14. Canon Vixia HF R500 Lens Cover Replacement: stap 14, afbeelding 1 van 1
    • Remove the single 5mm Phillips #000 screw located on the top of the camera near the lens cover.
  15. Canon Vixia HF R500 Lens Cover Replacement: stap 15, afbeelding 1 van 1
    • Unplug the cord connecting the camera to the lens cover. Grip the white plug near the port and pull it out.
    • Do not pull the cord by the wires. Grip the white plastic plug.
  16. Canon Vixia HF R500 Lens Cover Replacement: stap 16, afbeelding 1 van 1
    • The lens cover is detached from the camera and can now be removed.
    • Repair or replace damaged components in the lens cover.
    • Ensure lens cover mechanism is free of debris.
Conclusie
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 9
Altijd: 717
