Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
Remove the four 8mm Phillips #1 screws, located in each corner of the device.
Grasp one half of the device's shell in each hand, and pull them apart. They are connected, so don't separate them completely.
Lift the side panel off to expose the inside of the printer.
Remove the four 8mm Phillips #00 screws that hold the upper circuit board to the shell.
Remove two 8mm Phillips #00 screws from the yellow board.
Remove the two 8mm Phillips #00 screws from the screen.
Lift off the circuit board, yellow board, and screen.
To separate the screen from the circuit board, grasp the data ribbon cable near the base of the black connector on the circuit board and pull parallel to the surface of the board, toward the screen.
