Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
Set the printer on its back so that the Paper Cassette sticks straight up in the air.
Pull the Paper Cassette out of the printer. It is guided by two studs that fit into the grooves on the underside of the cassette.
Slide the translucent top cover of the Paper Cassette back to expose the paper storage area.
With the top half pulled back, lift the glossy side and open the Cassette.
Slide the upper clear plastic part back by gripping it on either side and pulling it backward.
Make sure the metal tab on the printer will fit over the paper in the Cassette.
Push the cassette into the printer, with the glossy side up. Make sure that the Cassette is being guided by the studs in the mouth of the printer.
Één andere persoon heeft deze handleiding voltooid.
