Ga door naar hoofdinhoud
Canon Selphy CP1200 Cooling Fan Replacement
Wat je nodig hebt
  1. Canon Selphy CP1200 Cooling Fan Replacement, LCD/Buttons: stap 1, afbeelding 1 van 1
    • Unscrew the four 6mm PH000 corner screws.
    • This will require a screwdriver with a long, narrow shaft.
  2. Canon Selphy CP1200 Cooling Fan Replacement: stap 2, afbeelding 1 van 1
    • Unscrew the three 4mm PH1 screws on the bottom of the printer.
  3. Canon Selphy CP1200 Cooling Fan Replacement: stap 3, afbeelding 1 van 1
    • Gently pry open the top of the case from either the front or back.
    • A plastic opening tool may help.
    • Be careful in lifting the top assembly as it is attached to the motherboard at this point.
  4. Canon Selphy CP1200 Cooling Fan Replacement: stap 4, afbeelding 1 van 1
    Gereedschap gebruikt in deze stap:
    Koop
    • Keeping the top assembly elevated, detach the ribbon cables connecting the LCD and buttons to the motherboard from the motherboard.
    • Tweezers may be useful given the limited space between the top assembly and motherboard.
    • The top assembly, containing both the LCD and buttons, will now be completely free
  5. Canon Selphy CP1200 Cooling Fan Replacement, Motherboard: stap 5, afbeelding 1 van 1
    • Detach the fan cable from the motherboard.
  6. Canon Selphy CP1200 Cooling Fan Replacement: stap 6, afbeelding 1 van 1
    Koop
    • Detach the ribbon cable leading to the DC in port and battery leads.
    • Tweezers may be useful.
  7. Canon Selphy CP1200 Cooling Fan Replacement: stap 7, afbeelding 1 van 1
    • Unscrew the three 3mm PH000 screws from the motherboard.
  8. Canon Selphy CP1200 Cooling Fan Replacement: stap 8, afbeelding 1 van 1
    • Disconnect the bundled cables leading to the printing mechanism.
  9. Canon Selphy CP1200 Cooling Fan Replacement: stap 9, afbeelding 1 van 1
    • Gently lift the motherboard and detach the ribbon cables leading to the print mechanism.
    • Tweezers may be useful due to the limited amount of space.
  10. Canon Selphy CP1200 Cooling Fan Replacement, Print Mechanism: stap 10, afbeelding 1 van 2 Canon Selphy CP1200 Cooling Fan Replacement, Print Mechanism: stap 10, afbeelding 2 van 2
    • Open the side door and depress the ink cassette release.
    • Slide out and remove the ink cassette.
  11. Canon Selphy CP1200 Cooling Fan Replacement: stap 11, afbeelding 1 van 1
    • Unscrew the three 3mm PH000 screws securing the metal plate to the printing mechanism.
  12. Canon Selphy CP1200 Cooling Fan Replacement: stap 12, afbeelding 1 van 1
    • Lift out the print mechanism of the printer case.
  13. Canon Selphy CP1200 Cooling Fan Replacement, Cooling Fan: stap 13, afbeelding 1 van 1
    • Lift out the back case plate.
  14. Canon Selphy CP1200 Cooling Fan Replacement: stap 14, afbeelding 1 van 2 Canon Selphy CP1200 Cooling Fan Replacement: stap 14, afbeelding 2 van 2
    • Remove the fan by tilting it forward slightly and then lifting upwards.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Één opmerking
Where can I get a new cooling fan for Selphy 1200
Roy johannessen - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 8
Altijd: 295
