Inleiding
The Canon SX40HS is a high-powered, user-friendly digital camera. The SX40 HS is a great entry-level camera that provides simplicity and quality at a low cost. Due to wear and tear, it is important to know how to change the flash cover. This guide is geared towards everyday photographers and professionals.
Wat je nodig hebt
Extend the flash cover upwards and remove the 4 mm black screw located on the left side. You will need a Phillips #00 screwdriver to remove it.
Repeat to remove the 4 mm black screw located on the right side.
To reassemble your device, follow Steps 1-4 in reverse order.
Één andere persoon heeft deze handleiding voltooid.
