Inleiding
User will need spudger, plastic pry tools, and PH00 screwdriver.
Wat je nodig hebt
Using the Phillips 00 screwdriver, remove the two 4mm top screws above the LCD screen.
Using spudger, lift the tab on the connector and remove the orange ribbon from motherboard (LCD screen is separated from camera).
Using the Phillips 00 screwdriver remove the seven 6mm screws from the housing plate of the LCD screen.
