Inleiding
User needs PH00 screwdriver, spudger, and plastic pry tool.
Wat je nodig hebt
Using the Phillips 00 screwdriver, remove the two 4mm top screws above the LCD screen.
Using the Phillips 00 screwdriver, remove the two 3mm screws closest to the right of the LCD screen.
Één andere persoon heeft deze handleiding voltooid.
