Ga door naar hoofdinhoud
Canon Powershot SX500 IS Control Dial Replacement
Wat je nodig hebt
  1. Canon Powershot SX500 IS Control Dial Replacement, Battery: stap 1, afbeelding 1 van 1
    • Rotate the camera to expose the underside of the camera.
  2. Canon Powershot SX500 IS Control Dial Replacement: stap 2, afbeelding 1 van 1
    • Slide the rounded rectangle tab to the left to release the battery cover.
  3. Canon Powershot SX500 IS Control Dial Replacement: stap 3, afbeelding 1 van 1
    • Push the small orange tab forward to release the battery (Battery is ready for removal).
  4. Canon Powershot SX500 IS Control Dial Replacement, Back Cover: stap 4, afbeelding 1 van 3 Canon Powershot SX500 IS Control Dial Replacement, Back Cover: stap 4, afbeelding 2 van 3 Canon Powershot SX500 IS Control Dial Replacement, Back Cover: stap 4, afbeelding 3 van 3
    • Using the Phillips 00 screwdriver, remove the two 4mm top screws above the LCD screen.
  5. Canon Powershot SX500 IS Control Dial Replacement: stap 5, afbeelding 1 van 1
    • Using the Phillips 00 screwdriver, remove the two 4mm side screws to the left of the LCD screen.
  6. Canon Powershot SX500 IS Control Dial Replacement: stap 6, afbeelding 1 van 1
  7. Canon Powershot SX500 IS Control Dial Replacement: stap 7, afbeelding 1 van 1
    • Using the Phillips 00 screwdriver, remove the three 4mm screws from the underside of the camera.
  8. Canon Powershot SX500 IS Control Dial Replacement: stap 8, afbeelding 1 van 2 Canon Powershot SX500 IS Control Dial Replacement: stap 8, afbeelding 2 van 2
    • Using the plastic pry tool, remove the back cover from camera.
  9. Canon Powershot SX500 IS Control Dial Replacement, Control Dial: stap 9, afbeelding 1 van 1
    • Using the Phillips 00 screwdriver, remove the two 3mm screws closest to the right of the LCD screen.
  10. Canon Powershot SX500 IS Control Dial Replacement: stap 10, afbeelding 1 van 1
    • Using the Phiillips 00 screwdriver, remove the 4mm screw to the right of the control dial.
  11. Canon Powershot SX500 IS Control Dial Replacement: stap 11, afbeelding 1 van 1
    • Using the spudger, lift the control dial to the right of the LCD screen.
  12. Canon Powershot SX500 IS Control Dial Replacement: stap 12, afbeelding 1 van 1
    • Using the spudger, lift the connection tab and remove the control dial's orange ribbon from motherboard.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Één opmerking
Gracias gracias gracias
edgarlugo20111917 - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 11
Altijd: 451
