Ga door naar hoofdinhoud
Canon Powershot SX30 IS Battery/SD Card Door Replacement
Wat je nodig hebt
  1. Canon Powershot SX30 IS Battery/SD Card Door Replacement, Battery/SD Card Door: stap 1, afbeelding 1 van 1
    • Open the protective door on the bottom of the camera, and remove the SD card and battery from the camera
  2. Canon Powershot SX30 IS Battery/SD Card Door Replacement: stap 2, afbeelding 1 van 2 Canon Powershot SX30 IS Battery/SD Card Door Replacement: stap 2, afbeelding 2 van 2
    • Unscrew the two 2mm screws from the inside of the case
  3. Canon Powershot SX30 IS Battery/SD Card Door Replacement: stap 3, afbeelding 1 van 2 Canon Powershot SX30 IS Battery/SD Card Door Replacement: stap 3, afbeelding 2 van 2
    • Remove the plastic backing and the metal front plate from the spring controlled hinge
    • To replace, hold the plastic backing to the metal hinge and screw the plate onto the front of it
Conclusie
That's It! Good Job!
Ellis DeVoe
580 Reputatie
5 handleidingen geschreven
Cal Poly, Team 5-12, Maness Spring 2015 Lid van Cal Poly, Team 5-12, Maness Spring 2015
CPSU-MANESS-S15S5G12
4 Leden
Één opmerking
What if the existing hinge is broken.....I need to replace the entire door and spring loaded hinge. Ya got instructions for that?
jusanotherhuman - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 3
Altijd: 634
