Ga door naar hoofdinhoud
Canon Powershot SX30 IS Back Camera Housing Replacement
Wat je nodig hebt
  1. Canon Powershot SX30 IS Back Camera Housing Replacement, Back Camera Housing: stap 1, afbeelding 1 van 2 Canon Powershot SX30 IS Back Camera Housing Replacement, Back Camera Housing: stap 1, afbeelding 2 van 2
    • Position the camera so that the right side is visible as shown.
    • Unscrew the two 6 mm screws shown using a screwdriver.
  2. Canon Powershot SX30 IS Back Camera Housing Replacement: stap 2, afbeelding 1 van 3 Canon Powershot SX30 IS Back Camera Housing Replacement: stap 2, afbeelding 2 van 3 Canon Powershot SX30 IS Back Camera Housing Replacement: stap 2, afbeelding 3 van 3
    • Remove the plastic flap by pressing down on the center of the hinge and pulling on the flap with the spudger.
    • Then, unscrew the lone 6mm screw that was under the plastic flap.
  3. Canon Powershot SX30 IS Back Camera Housing Replacement: stap 3, afbeelding 1 van 2 Canon Powershot SX30 IS Back Camera Housing Replacement: stap 3, afbeelding 2 van 2
    • Turn the camera so that the bottom is visible, as shown.
    • Unscrew the three 4mm screws shown red using a screwdriver.
    • Unscrew the single 6mm screw.
    • Do not touch the screw shown yellow, removal is unnecessary. (Note: the top right yellow screw should be removed)
  4. Canon Powershot SX30 IS Back Camera Housing Replacement: stap 4, afbeelding 1 van 1
    • Turn the camera so the back side is visible, as shown.
    • Unscrew the two 6mm screws.
  5. Canon Powershot SX30 IS Back Camera Housing Replacement: stap 5, afbeelding 1 van 1
    • Gently remove the back cover using the spudger.
    • Exercise caution, as the wire inside is fragile.
  6. Canon Powershot SX30 IS Back Camera Housing Replacement: stap 6, afbeelding 1 van 2 Canon Powershot SX30 IS Back Camera Housing Replacement: stap 6, afbeelding 2 van 2
    • Detach the wire by lifting the small black bar that holds it to the main body of the camera.
  7. Canon Powershot SX30 IS Back Camera Housing Replacement: stap 7, afbeelding 1 van 1
    • Attach the new cover onto the camera.
  8. Canon Powershot SX30 IS Back Camera Housing Replacement: stap 8, afbeelding 1 van 1
    • Reattach the wire to your new rear casing.
  9. Canon Powershot SX30 IS Back Camera Housing Replacement: stap 9, afbeelding 1 van 1
    • Close the back cover, and re-insert appropriate screws.
Conclusie
Ellis DeVoe
580 Reputatie
5 handleidingen geschreven
Cal Poly, Team 5-12, Maness Spring 2015 Lid van Cal Poly, Team 5-12, Maness Spring 2015
CPSU-MANESS-S15S5G12
4 Leden
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 7
Altijd: 1,237
