Ga door naar hoofdinhoud
Canon Powershot SD880 Top Panel Replacement
Wat je nodig hebt
  1. Canon Powershot SD880 Top Panel Replacement, Back Cover: stap 1, afbeelding 1 van 3 Canon Powershot SD880 Top Panel Replacement, Back Cover: stap 1, afbeelding 2 van 3 Canon Powershot SD880 Top Panel Replacement, Back Cover: stap 1, afbeelding 3 van 3
    • Remove the two 2.4 mm screws on the side of the camera that are next to the LCD screen using a Phillips #00 screwdriver.
    • Remove the two 4.1 mm screws on the other side using a Phillips #00 screwdriver.
    • One screw will be located under the rubber USB flap.
    • Remove the single 2.6 mm screw from the bottom of the camera using a Phillips #00 screwdriver.
    • Slowly pull the back cover off of the camera.
  2. Canon Powershot SD880 Top Panel Replacement, Top Panel: stap 2, afbeelding 1 van 2 Canon Powershot SD880 Top Panel Replacement, Top Panel: stap 2, afbeelding 2 van 2
    • Unplug the green and white plugs that connect the top panel to the top of the logic board.
    • Dislodge the tab above the lens.
    • Dislodge the tab at the back.
Conclusie
Robert Manno
432 Reputatie
4 handleidingen geschreven
Cal Poly, Team 13-3, Forte Winter 2011 Lid van Cal Poly, Team 13-3, Forte Winter 2011
CPSU-FORTE-W11S13G3
5 Leden
8 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 5
Altijd: 1,044
