Ga door naar hoofdinhoud
Repareer je spullen
Recht op reparatie
Winkel
Onderdelen
Geen onderdelen opgegeven.
  1. Deze stap is niet vertaald. Help het te vertalen
    Turn the camera to the side that has the attachment for the wrist strap.
    • Turn the camera to the side that has the attachment for the wrist strap.
    • Unscrew the two black 3.4 mm screws with a #00 Phillips screwdriver.
  2. Deze stap is niet vertaald. Help het te vertalen
    Remove the plastic subsection by prying it with your fingers.
    • Remove the plastic subsection by prying it with your fingers.
    • Note: It may be helpful to pry from the bottom of the camera with the battery door open.
    • The wrist strap attachment behind the subsection will come loose and may fall out.
  3. Deze stap is niet vertaald. Help het te vertalen
    Turn the camera over to the side opposite of the wrist strap.
    • Turn the camera over to the side opposite of the wrist strap.
    • Remove the two silver 3.4 mm screws with a #00 Phillips screwdriver.
  4. Deze stap is niet vertaald. Help het te vertalen
    Flip the camera upside down.
    • Flip the camera upside down.
    • Remove the following screws with a #00 Phillips screwdriver.
    • One black 3.4 mm Phillips screw.
    • One silver 3.4 mm Phillips screw.
    • NOTE: Using your fingernails may help in removal.
  5. Deze stap is niet vertaald. Help het te vertalen
    Place the camera on the side opposite of the wrist strap handle.
    • Place the camera on the side opposite of the wrist strap handle.
    • Then begin to pry the casing apart with both hands by applying pressure to the top and bottom of the camera.
    • Remove the small metal plate underneath the plastic covering and set aside. (It should be loosely attached)
    • Note: A rubber foam washer that separates the lens from the casing will fall off when the case is removed. Be sure to store it safely.
    • Note: When reassembling ensure the back plate screw tabs are over the wrist strap attachment and the front plate screw tabs go under orange casing.
  6. Deze stap is niet vertaald. Help het te vertalen
    Flip the camera right side up.
    • Flip the camera right side up.
    • Remove the silver 3.5 mm screw (located on top of the camera) with a #00 Phillips screwdriver.
    • Grip the corner of the A/V digital port and pull up and outward.
    • Note: You may encounter some resistance when removing the A/V digital port. Apply enough pressure in order to remove this piece.
    • Note: When reassembling, snap the corner plate back into its position. (Push down and inward)
  7. Deze stap is niet vertaald. Help het te vertalen
    Turn the camera forward so that the LCD screen is facing you.
    • Turn the camera forward so that the LCD screen is facing you.
    • Remove the silver 3.4 mm screw at the top right hand corner of the LCD screen with a #00 Phillips screwdriver.
  8. Deze stap is niet vertaald. Help het te vertalen
    Slide the LCD screen to the left of the camera and then gently pull the LCD screen away from the camera.
    • Slide the LCD screen to the left of the camera and then gently pull the LCD screen away from the camera.
    • Note: Hold the screen and frame together.
    • Be sure to align the screen properly.
    • Be gentile and do not tear the ribbon connector for the LCD screen to camera.
  9. Deze stap is niet vertaald. Help het te vertalen
    Locate the two ribbons connected to the camera and the LCD screen. (One is red and small and the other is  wide and orange) Remove the top left red ribbon  by gripping the connector on the camera and sliding it straight out.
    • Locate the two ribbons connected to the camera and the LCD screen. (One is red and small and the other is wide and orange)
    • Remove the top left red ribbon by gripping the connector on the camera and sliding it straight out.
    • Remove the side orange ribbon by gripping the connector on the camera and sliding it straight out.
    • Note: It may be helpful to use tweezers when removing the connectors. (Pay close attention to how the ribbons are disconnected as this will help in replacing the screen later)
    • Note: When reassembling, use tweezers to reconnect the small red connector on the top left of the screen.
  10. Deze stap is niet vertaald. Help het te vertalen
    Place the camera forward so that the LCD screen side is facing up. Remove the circular plastic button from the back of the camera.
    • Place the camera forward so that the LCD screen side is facing up.
    • Remove the circular plastic button from the back of the camera.
    • Be sure to set the circular plastic button aside.
  11. Deze stap is niet vertaald. Help het te vertalen
    Leave the camera facing forward.
    • Leave the camera facing forward.
    • Grab the round orange and black stripped connector as pictured.
    • Then rotate the connector upward and pull the ribbon out.
  12. Deze stap is niet vertaald. Help het te vertalen
    Place the camera backward so that the lens is facing up. Disconnect the ribbon that attaches to the motherboard by rotating the connector upwards.
    • Place the camera backward so that the lens is facing up.
    • Disconnect the ribbon that attaches to the motherboard by rotating the connector upwards.
    • Pull the ribbon out of the ZIF connector.
  13. Deze stap is niet vertaald. Help het te vertalen
    Stand the camera upward.
    • Stand the camera upward.
    • Disconnect the white connector attached to the flash by pulling it out on the top right side of the camera.
    • Then remove the orange circuitry.
  14. Deze stap is niet vertaald. Help het te vertalen
    • Disconnect the ribbon at the bottom of the main board by flipping up the brown ZIF connector and sliding the ribbon out.
    • Note: Tweezers are recommended to perform this step.
    • Remove the right most square connector at the bottom of the camera by flipping up the connector with two fingers until it detaches.
    • Locate and remove the white rubber cover on the microphone.
    • Note: Be sure not to lose the white rubber cover for the microphone.
  15. Deze stap is niet vertaald. Help het te vertalen
    Leave the camera facing backward so that the lens is facing up. Remove the square connector at the top of the motherboard by grabbing the connector with two fingers and pulling up until it detaches.
    • Leave the camera facing backward so that the lens is facing up.
    • Remove the square connector at the top of the motherboard by grabbing the connector with two fingers and pulling up until it detaches.
    • Refer to the picture for correct removal.
  16. Deze stap is niet vertaald. Help het te vertalen
    Leave the camera facing backward so that the lens is facing up. Flip up the ZIF locking mechanism using a paperclip
    • Flip up the ZIF locking mechanism using a paperclip
    • Note: Place the paper clip in the holes on either end of the ZIF locking mechanism.
    • Use the paperclip to pull the ribbon cable from the ZIF socket.
  17. Deze stap is niet vertaald. Help het te vertalen
    • Remove the two flat silver 3.46 mm Phillips screws with a #00 Phillips screwdriver connecting the motherboard to the frame of the camera.
  18. Deze stap is niet vertaald. Help het te vertalen
    • Pull the motherboard out by lifting it up on the left side about a 1/2 inch from the case and then slide it to the left.
    • Note: When reassembling, make sure the ZIF connectors are not covered by motherboard.
    • Caution: When removing the motherboard, pay special attention to the battery door detection switch or you may break the plastic nib.
Eindstreep
Één andere persoon heeft deze handleiding voltooid.
William
121 Reputatie
2 handleidingen geschreven
Cal Poly, Team 14-37, Forte Fall 2010 Lid van Cal Poly, Team 14-37, Forte Fall 2010
CPSU-FORTE-F10S14G37
4 Leden
6 handleidingen geschreven
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 2
Altijd: 5,111
