Inleiding
Many companies sell only LCD screens, not complete screen assemblies. When replacing your broken LCD screen, it may be necessary to tear down the screen even further.
Onderdelen
Geen onderdelen nodig.
In preparation for disassembly, the battery and SD Card need to be removed from the camera. You can access both the battery and the SD card through the door on the bottom of the camera.
  • In preparation for disassembly, the battery and SD Card need to be removed from the camera. You can access both the battery and the SD card through the door on the bottom of the camera.
Voeg opmerking toe
While being careful to remember the original location of each screw, remove the three 0.15 inch screws on the underside of the camera.
  • While being careful to remember the original location of each screw, remove the three 0.15 inch screws on the underside of the camera.
  • Each of the screws is slightly different, so it is important that you note the original location of each screw.
Voeg opmerking toe
Find the next two screws on the right side of the camera. One of them is hidden under the USB port cover. The upper screw is .125 inches long, while the lower screw measures .085 inches. Remove both screws, then carefully lift the side panel off. Underneath the side panel, there is a .07 inch screw. Remove it.
  • Find the next two screws on the right side of the camera. One of them is hidden under the USB port cover. The upper screw is .125 inches long, while the lower screw measures .085 inches.
  • Remove both screws, then carefully lift the side panel off.
  • Underneath the side panel, there is a .07 inch screw. Remove it.
Voeg opmerking toe
Mac RAM Kits
Speed up your Mac. Max out its memory.
Mac RAM Kits
Get more memory out of your Mac.
On the left side of the camera, there are two .085 inch screws. Remove these, then lift the plate from the camera. On the left side of the camera, there are two .085 inch screws. Remove these, then lift the plate from the camera. On the left side of the camera, there are two .085 inch screws. Remove these, then lift the plate from the camera.
  • On the left side of the camera, there are two .085 inch screws. Remove these, then lift the plate from the camera.
Voeg opmerking toe
Now the camera body is loose. gently lift the rear of the case to remove it from the camera. Now the camera body is loose. gently lift the rear of the case to remove it from the camera. Now the camera body is loose. gently lift the rear of the case to remove it from the camera.
  • Now the camera body is loose. gently lift the rear of the case to remove it from the camera.
Voeg opmerking toe
Next, remove the front of the camera body. Be sure to keep track of the rubber ring. You have now successfully removed the outer case. You have now successfully removed the outer case.
  • Next, remove the front of the camera body. Be sure to keep track of the rubber ring.
  • You have now successfully removed the outer case.
Voeg opmerking toe
Next, peel the navigation buttons from the button panel and set them aside. To free the LCD display, remove the .113 inch screw in the top left corner. Then, rotate the screen clockwise until it lifts away from the camera.
  • Next, peel the navigation buttons from the button panel and set them aside.
  • To free the LCD display, remove the .113 inch screw in the top left corner.
  • Then, rotate the screen clockwise until it lifts away from the camera.
  • There are two ribbon cables attached to the rear of the screen. Do not try to pull the screen off at this point.
Voeg opmerking toe
To unplug the ribbon cables, pull them straight out of their plugs. Do this gently to avoid damaging the connections. After disconnecting both cables, pull the screen away from the camera to remove it.
  • To unplug the ribbon cables, pull them straight out of their plugs. Do this gently to avoid damaging the connections.
  • After disconnecting both cables, pull the screen away from the camera to remove it.
Voeg opmerking toe
In order to remove the LCD from its mount, carefully pry up the four tabs along the top and bottom edges of the screen. There is a reflector sheet under the screen that is easily scratched. Try not to touch the reflector as it is nearly impossible to clean. You have now successfully disassembled the LCD.
  • In order to remove the LCD from its mount, carefully pry up the four tabs along the top and bottom edges of the screen.
  • There is a reflector sheet under the screen that is easily scratched. Try not to touch the reflector as it is nearly impossible to clean.
  • You have now successfully disassembled the LCD.
Voeg opmerking toe
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Matthew Theiss
107 Reputatie
4 handleidingen geschreven
Cal Poly, Team 18-23, Garner Spring 2011 Lid van Cal Poly, Team 18-23, Garner Spring 2011
CPSU-GARNER-S11S18G23
5 Leden
8 handleidingen geschreven
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 Uren: 0
Afgelopen 7 Dagen: 1
Afgelopen 30 Dagen: 5
Altijd: 1,872
