Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
Remove the three 3.8 mm screws from the underside of the camera.
Remove the 3.2 mm screw from the right side of the camera.
Remove the 2.2 mm screw from the right side of the camera.
Lift the side panel off.
Remove the 1.8 mm screw from underneath the side panel.
Remove the two 2.2 mm screws from the left side of the camera.
Lift the plate from the camera.
Gently lift the rear of the case to remove it from the camera.
Peel the navigation buttons from the button panel and set them aside.
To free the LCD display, remove the 2.9 mm screw in the top left corner.
Rotate the screen clockwise until it lifts away from the camera.
To unplug the ribbon cables, pull them straight out of their plugs. Do this gently to avoid damaging the connections.
After disconnecting both cables, pull the screen away from the camera to remove it.
Één andere persoon heeft deze handleiding voltooid.
